Design SuiteExporting resources
If you create custom resources and reuse them frequently, you may want to organize them into resource libraries. You and other users can add the libraries to your Favorites, User Libraries, or Workgroup Libraries, and then easily use resources from them. See Concept: Resource libraries.
In the Vectorworks Design Suite products, use the export function of the Resource Manager to export one or more resources or resource folders from the active file to another file, without opening the target file.
To export resources or resource folders:
From the Resource Manager, select the active file from the Open Files list.
Select one or more resources or resource folders to export.
Right-click on the resource/folder, and select Export from the context menu.
The Export Resource dialog box opens.
Parameter
Description
Destination list
Displays Recent Export Files, Resource Manager Favorites, Libraries, and Currently Open files. Either select a file from the window and click OK, or click Browse to select a file from another location.
If the resource is to be exported to one of the default content folders within the user folder (Libraries\Defaults), place the file within a subfolder if one exists.
Browse
Specifies a different location for the exported resource
Preserve folder hierarchy
During export, maintains the same folder structure the exported resource had in its source file
If the target file already contains a different resource with the same name, you are prompted to resolve the Resource name conflict.
Drag and drop exporting
A fast way to export is to simply drag and drop one or more resources from any file to any file or folder in your Open Files, Favorites, User Libraries, or Workgroup Libraries. If you drag a resource to one of the Vectorworks Libraries, an alert displays.
